Question LG led TV Image flashing spots
Discussion in 'LG TVs Forum' started by icemanfrosty, Jun 12, 2018.
  1. icemanfrosty
    icemanfrosty
    Sep 20, 2010
    184
    Tewkesbury
    +18
    Hi all, I have had a 50" 3D LG LED TV for just over 2 years and it has been a good set till now.
    When you switch it on there is patches in the middle and there are patches at the bottom that go bright then dark. They look like a circle around the size of a tennis ball and very easy to see but when the tv warms up it stops.
    Any Ideas would be great thanks, before I strip it down and check for blown caps on the back-light board
  2. LGSAM
    LGSAM
    Jun 27, 2013
    +3
    Hi , It could be the LED's . I have seen cases where they burnt through the strips , but to find out you will have to remove the panel and diffuses
  3. icemanfrosty
    icemanfrosty
    Sep 20, 2010
    184
    Tewkesbury
    +18
    Hi Thanks for the reply, if that is the issue is it a easy fix? Or should I just get a new TV.
    Thanks.
  4. LGSAM
    LGSAM
    Jun 27, 2013
    +3
    I think you can get the LED strips on E bay , It might be a tricky job if you can get the correct parts .
    Good Luck
