LG LCD TV fault
Discussion in 'LG TVs Forum' started by duncan1000, Oct 13, 2004.
  1. duncan1000
    duncan1000
    I've just got an LG LCD almost straight away it's developed a thin blue line running vertically down the left side of the screen
    Is this a fault with the screen or could it be interference? I've checked all the cabling
  2. spergabite
    spergabite
    Jul 23, 2004
    46
    Take it back, its a fault - ive seen many like this on laptops at work(plus lcds generall dyont suffer from interference ...)
  3. tony22
    tony22
    Oct 8, 2009
    2
    Hi spergabite, I also have the blue line fault but on the right hand side of the screen, my TV is 4 years old and out of insurance, the blue line appeared shortley after inserting a new SKY card, can you advise me.
  4. ProDave
    ProDave
    Mar 6, 2007
    325
    +36
    That blue line is not a TV fault, but a "feature" of the new sky HD EPG. Confirm that by viewing a different video source or terestrial tv.
  5. tony22
    tony22
    Oct 8, 2009
    2
    Thank you Prodave.
  6. gusjux
    gusjux
    Jul 14, 2009
    341
    +19
    I had exactly the same problem with my LG 42LH3000 after 6 weeks. Contacted the retailer I bought it from & they sent a "technician" out who told me the panel was faulty and would need replacing. After about 3 weeks of waiting the retailer told me LG would write off the tv instead and I got a replacement tv (which was also faulty!!!).
    Sounds like you should have no problems getting a refund or replacement as its new.
