LG LCD Inputs - Help
Discussion in 'LCD & LED LCD TVs' started by GMann, Jul 25, 2005.
  1. GMann
    GMann
    I may be being fick - I was about to purchase the new LG M3700C LCD Monitor (37 inch) but having looked through the manual the only inputs are:
    2 x RGB presented as HD15 pin connections
    1 x S-Video presented as standard S-Video
    1 x AV presented as RCA's yellow, red and white
    1 x Component in presented at 3 x RCA's for video (Y, PB, PR) and two RCA for audio (red and white)
    1 x Component in (480/576) presented as 3 x RCA's for video (Y, PB, PR) and two RCA for audio (red and white)
    1 x DVI-D as a DVI-D cable
    The problem is that I have two devices to connect, Sky+ and DVD player. The DVD player can use the S-Video but it will also need to connect to the RCA left and right audio also used by the AV input (as per the manual).
    This is fine but then what the hell do I connect my Sky + box to? it does not have component out or RGB on HD15 pin!!!
    Any suggestions????
