LG LC37LC2DB & Sky+ remote code (rev 6)
Discussion in 'LCD & LED LCD TVs Forum' started by Sid and Coke, Dec 19, 2006.
Tags:
  1. Sid and Coke
    Sid and Coke
    May 26, 2002
    43
    East Scotland
    Has anybody got one of these TV's and Sky+ can you please tell me which code you used so the Sky+ remote operates the TV.
    My Sky+ remote has Rev 6 printed on a label on the back..
    I've tried wading through the list of codes and it still doesn't seem to work. I also seem to recall from when i first got Sky+ that programming the remote wasn't quite as straightforward as the instruction manual suggests, something about the way the buttons are pressed, it has been a while now...;)
  2. bsj
    bsj
    Oct 9, 2006
    28
    3
    Code 206 worked for me with 42" LC2D and sky hd remote.
  3. Sid and Coke
    Sid and Coke
    May 26, 2002
    43
    East Scotland
    Code 206 was no good for me. I was also told by Sky+ CS to pre-fix the 3 digit code with an extra 0 for a rev 6 remote but that didn't work either.
    getting pretty hacjked off with this, i had no hassles with my previous Panasonic CRT tv....
  4. bsj
    bsj
    Oct 9, 2006
    28
    3
    Did you try the alternative set up in the sky + instruction book, that worked for me.
  5. SAH
    SAH
    Feb 28, 2004
    1,721
    48
    +75
    Just tried 206, worked first time with a LG 32LX2-R TV and Sky HD!
  6. Sid and Coke
    Sid and Coke
    May 26, 2002
    43
    East Scotland
    Just bought a Rev -8 remote off e-bay. After a bit of messing about and swearing ( probably due to operator error) I got it to work by doing the following onthe remote;
    • Press TV button.
    • Press & hold Select and Red button together for 2+ secs ( LED flashes twice ).
    • Press 9, 9, 9, ( LED Flashes twice ).
    • Press TV.
    • Press & hold for 2+ secs Select & Red button together, (LED flashes twice ).
    • Press 2, 0, 6, Select, ( red LED flashes twice )
    This process worked for me on an LG 37LC2D TV.
  7. pjfair
    pjfair
    Nov 19, 2006
    Well done Sid. Just bought my new Sky+ REV 8 from ebay and 206 code now operates my 37LC2D. For all others looking for a code for the REV 6 remote then stop wasting your time. New rev 8 available all over eBay and even change ARC by pressing TV then play. Good remotes, original and only a tenner.
    Just noticed, press tv then help to get selection of inputs. AV1 AV2 etc.
  8. topper22
    topper22
    Jan 10, 2007
    10
    Hi pjfair, thanks for this, just ordered a rev-8 off ebay, was really annoying not being able to control TV through rev-6 remote.
    What does ARC stand for ? and can you really get a list of inputs through the Sky+ remote? That would be great, I would then never have to use the original TV remote to change between AV-3 and Component!! (Sky SD and Xbox 360 ).
