Hello, I hope someone could help to see if my TV I able to do what I want or not. I have an LG 55LB6500, which I used to be connected to an old Sony soundbar, using the ARC port, and everything was working well, I was receiving DD from the TV and because my Fire TV was connected directly to the soundbar into a secondary HDMI I was receiving DD from the firetv as well.
Now I have upgraded my old soundbar to a Sonos ARC, but because this one only has one HDMI port, I was able to only connect the TV, using the ARC HDMI port, to the soundbar and had to connect my FireTv to another HDMI port in the TV, but now I only received DD 5.1 using the TV apps If I use the fireTV it only transmits PCM stereo. Shouldn't it passthrough DD 5.1 from the other HDMI ports through the HDMI ARC connected to the soundbar?
I can have DD 5.1 for Netflix and Amazon, but because the TV is quiet old, 2015 I think, it doesn't have Disney+ or HBO Max, so for this, I have to use my FireTV but I would like to have at least DD 5.1 sound and not only PCM Stereo. Is there any way I can work around this?
