Lg lamp hour resetting
Discussion in 'General TV Discussions Forum' started by aaeon.1, Dec 22, 2004.
  1. aaeon.1
    aaeon.1
    hey guys have a 60 inch lg dlp and the optical generator **** itself so the guy came and changed it and the lamp under warranty but he did not know how to reset the lamp hours and as i had 4800 hours on the old lamp i would like to know how to set the lamp hours back to zero so i know how many actual hours the lamp has done
    tried ringing lg and they seem to think its all secret squirrel stuff but as i pointed out that if i,m gonna spend that much on a tv then i really dont have many quarms about replacing the bulb every 10 000 hours i just want to reset the the thing
    aaeon.1
  2. Morbius
    Morbius
    Oct 21, 2003
    Glasgow
    Try phoning Barron McCann in Derby who look after LG DLP's - replaced my bulb within warrant on the LG44sz21RD . The technical people are very approachable and gave me a lot of info on the set
    number +441332866935 or direct to technical 01332866562
    regards
    Stu
  3. aaeon.1
    aaeon.1
    thanx stu
    mine is the LG MW-60SZ12
    great picture and a good looking unit too
  4. aaeon.1
    aaeon.1
    have no idea about the uk
    but they are fairly easy to come by in australia
    bought mine here in tasmania as an ex display model still under warranty for a song
  5. aaeon.1
    aaeon.1
    your right there lion
    but its the thought that counts
    anyway back to my original question
    does anyone out there no how to reset the lamp hours on one of these babies
    aaeon
  6. aaeon.1
    aaeon.1
    alrighty guys have the answer for those of you that have a lg dlp
    press the menu button on the front panel
    while holding button on panel press and hold the menu button on the remote control
    service menu will appear and then keep pressing the menu button until you come to lamp hour resetting
    press ok on remote
    and now lamp hour is reset
    good luck with it
    aaeon
  7. willus
    willus
    I've posted more detailed instructions on resetting the lamp hours on an LG DLP (RU44SZ61D) TV here:
    http://willus.com/author/dlptv.shtml
    which I re-cap here:
    1. With the TV on, press and hold the MENU button on the TV front panel.
    2. While holding that button, press and hold the MENU button on your remote.
    3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
    4. Release the remote MENU button first, then the TV MENU button.
    5. Press and hold the ENTER (or OK) button on the TV front panel.
    6. While holding that button, press and hold the MUTE button on the remote.
    7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
    8. Release the MUTE button first, then the ENTER button on the TV front panel.
    9. Make a note of the lamp hours if you want.
    10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
    11. It will ask you to confirm the reset--press SELECT again to confirm.
    To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
    -willus
  8. TylerAsmann
    TylerAsmann
    That last post was right, except that steps 5 and 6 need to be switched around. Press and hold the mute button first, then press and hold the enter button.
  9. Hallzy04
    Hallzy04
    May 12, 2015
    Tasmania
    Hey guys,
    I have a LG 62DC1D-AB projecter tv. I have the same problem with mine, although I have read and followed each step several times but hasn't worked? When the life hour counter appears I confirm by pressing the ok button on the remote and it comes up with initializing? I confirm by pressing ok again, although it does the same and switches off? If anyone has any solution to this and could help me it would be much appreciated. Thanks :)
