LG HT552TH - RGB via Scart?
Discussion in 'Home Cinema Buying & Building' started by dversteeg, Jan 11, 2008.
  1. dversteeg
    dversteeg
    Sep 8, 2004
    140
    Nottingham
    +8
    Hi!
    Quick and simple question:
    I'm looking at the LG HT552TH and currently use the JS RGB to VGA convertor with my Panny PW6, so I want to know if the LG outputs in RGB via it's scart? I can't seem to find the answer anywhere!
    Hope someone can give me a quick yes or no!
    Cheers,
    D
  2. dversteeg
    dversteeg
    Sep 8, 2004
    140
    Nottingham
    +8
    Not to worry, i bit the bullet and tried it and it works a treat! So the answers yes!
