Quantcast
LG HR650/600 3D Blu ray player
AndyTheBubble
Hello All,
I hope someone can answer these relatively simple questions.
If I purchase a 3D blu-ray player, will it play in a 3D mode, on a non-3D TV. So all I would need are the glasses?
If someone has a 3D TV, I understand it will create a 3D image, when displaying a normal Blu-Ray? If so, what is the point in then buying a 3D player?
soundstory
Hello All,
Ok, this needs to go into this section
3D TV Technology | AVForums.com - UK Online
But & how can I put this, I'd read your question again before you post!
AndyTheBubble
First of all, I included it in this area - because it is a question about players aswell as 3DTV.
I have re-read it, and I have constructed the questions slightly differently:
Will a 3D blu-ray player produce a 3D image on a non-3D TV if I used the special 3D glasses?
Will a 3DTV produce a 3D image even with a normal Blu-Ray?
I hope this is clearer. Any advice, welcomed
Indiana Jones
To view 3D Blu-rays you need to have both a 3DTV and a 3D Blu-ray player, you can't just use the glasses on a normal TV.
You can watch a normal BD on a 3DTV and have it convert to 3D but this is not the same, to get the most out of a 3DTV it should be paired with a 3D Blu-ray player and proper 3D Blu-ray films.
Similar threads
