LG home cinema
Discussion in 'AV Receivers & Amplifiers' started by k.monaghan, Dec 12, 2001.
  1. k.monaghan
    k.monaghan
    Has any body any views on a LG Home cinema system sold by Dixons. This has a dvd and radio combined .
  2. Doubledoom
    Doubledoom
    R2 only machine
    has one scart, which is not RGB enabled (according to site specifications)
    No mention of the number of analogue inputs (3 is minimum you would want).
    It's cheap, cheerful, better than your tv but suffers all the usual problems attached to all-in-ones.
  3. k.monaghan
    k.monaghan
    What problems are associated with all in one`s home cinema systems. I also looked at a Panasonic all in one\ I believe the model was something HT80 ?
  4. Doubledoom
    Doubledoom
    There are about 3 threads a week on the all-in-ones
    generally, they are:
    1 - over priced for what you get
    2 - Poor connectivity (lacking scarts in some cases and not enough analogue inputs for all your items)
    3 - If one bit goes wrong, you stand to lose the whole lot. Equally, you lose the upgrade path.
    4 - low output speakers
    5 - not as many features as seperates.
    They are a good idea but poorly implemented. The idea probably came about when seperates where more expensive than they are currently and people didn't have some many external sources. However, that has changed but the all-in-ones havent
