LG HB965TZ Wireless Connectivity Issues
Discussion in 'Home Cinema Buying & Building' started by 1967ajd, Dec 7, 2011.
  1. 1967ajd
    1967ajd
    Dec 7, 2011
    Afternoon all, new member so please be gentle.
    After sending my first whistler back, I decided to chance my arm again (£100 cheaper was a factor) and get another one from Hughes Direct via Amazon.
    This one works perfectly (may be the manufacture date, Jan 2011 as opposed to the returned April2010).
    Only issue is that on the first kit it showed the MAC address in the network setup menu so this could be added to my router access list, the new one does not.
    Any ideas? Cheers
  2. Buttox Brown
    Buttox Brown
    Nov 14, 2009
    253
    +14
    You usually enable sharing in your media player on your computer and input your access password when setting up your wireless network from the main menu from the blu ray.
