Hi, I noticed that noones mentioned anything more on this in a while and since I was looking at the same system I was hoping someone might have some more feedback for me on this system. The cheapest I've seen this system for is £195 at amazon (link below).
LG HB405SU 5.1 Blu-ray Home Cinema System with DLNA: Amazon.co.uk: Electronics
This seems like a really good price for a 5.1 system with blu ray (cheapest one I've found) yet the one amazon and play.com appear to be very positive.
Any feedback would be appreciated!
For its price, you get a lot for your money. The speaker output is 400w which makes it perfect for smaller room sizes. The HB905SU packs more watts making it possibly a better choice for large spaces.
The beauty of this system is that it plays virtually everything you throw at it. I have it connected to my router, which means you can stream files to it from your computers. I mainly use this for DivX and MKV Blu-Ray. It also plays SRT subtitle files. You can also plug in your USB drive with a DivX or MKV movie directly if you prefer.
The LG menu looks nice, perhaps moving around in the menus isn't as fast as say your computer but nothing really upsettingly slow.
It also comes with Netcast, which offers Picasa, Youtube and Weather via the Internet. I have used the Youtube feature but trying to search via your remote control is rather time consuming. Plus it has its own interface which unfortunately does not allow you to select the HD version of Youtube videos. A missing feature I would say as you are not able to get any decent picture quality from the regular Youtube videos, especially watching them on a large-ish screen (mine is 46").
The system takes a few seconds to boot up, perhaps 10 seconds, which might put some people off. You can't just use the player as a CD player by putting a CD in and pressing play. It needs to go through the booting cycle when you turn it on. Another downside perhaps. I don't use CDs as I stream all my music from a media server to the LG.
The sytem has two optical inputs, one of which is connected to a BT Vision box in case they stream movies with 5.1 surround. Not all Blu-Ray 5.1 systems actually have an optical output so I consider this a plus.
It also allows you to configure the output of each individual speaker, so if you want a bigger punch in your rear satellites, this would be possible (or to turn the base unit down).
The system lacks a earphones output for some strange reason. I don't really know why they left this off as I am not able to listen to the sound in all peace and quiet without disturbing anybody else. The lack of this feature might actually put some people off when considering buying this unit.
I bought the system as it comes with the networking feature and attractive small satellite speakers that fit nicely in my lounge. And for a price of under £200 you can not really go wrong. I have seen them advertised for a lot more in retail shops so be careful to find yourself the best deal via Google Produc Search.
Very happy with it, although it would be completely perfect for me if it would do/contain the following:
- Better Youtube interface with 720p/1080p video option
- More widgets on LG Netcast (The US version offers oodles more content)
- Earphones output
- Gigabit wired network connection
- Wifi 802.11n connection
- Instant CD/MP3 play without having to boot to the menu first
- Thicker speaker cables which clip into the back of the speakers (I changed all the cabling, but had to unscrew, resolder and modify the hole in the speaker to fit better cabling)
Hope this helps a bit, if you have any other questions, please feel free to ask.
Seb.
