cecemf
Established Member
if you have an AV Receiver or sound bar no issuesOk, so im i a little concerned here about DTS. does this mean that any DTS source won't output ANY sound? What about Plex content that is DTS?
I use a Denon 6400h. Will the TV passthrough the DTS without transcoding on the server? If anybody can actually test this if it works in real situations would be great.if you have an AV Receiver or sound bar no issues
Connect all sources to your AV Receiver then AV Receiver to your TV via eARC and you sorted you will hve DTS sound from those sources (like Bluray player)I use a Denon 6400h. Will the TV passthrough the DTS without transcoding on the server? If anybody can actually test this if it works in real situations would be great.
That doesn't look fine for meHey everyone. Yesterday I purchased my G1 and have only just got round to playing with it after mounting it yesterday. Whilst inspecting it I noticed this very straight 'crack' just above the IR receiver. I'm convinced it isn't normal, could someone clarify this for me?
Hi, It's the same on my 1-month-old 55" G1, so yes it's normalHey everyone. Yesterday I purchased my G1 and have only just got round to playing with it after mounting it yesterday. Whilst inspecting it I noticed this very straight 'crack' just above the IR receiver. I'm convinced it isn't normal, could someone clarify this for me?
Well that is a relief, thanks for thatHi, It's the same on my 1-month-old 55" G1, so yes it's normal
I thought I inspected my new toys with a keen eye!
Sit back and enjoy!
This has been discussed before...its normal, I have it on my 65G1, everyone has this if you look close up. Don't worry, enjoy!
Does the LG G1 have a plastic film on the back that you need to peel off, like the CX/C1? Only asking as it’ll be getting wall mounted straight out of the box and I’m not going to get chance to check this.
Also, with the included flush mount are there any quirks that a new owner needs to be aware of?
Such as any difficulties with moving the TV towards and away from the wall with ease - just in case cables need switching or the TV needs to be taken down[/QUOTE
No, just the protective film on the screen.
I didn't have any plastic film on the back of my 55" G1.Does the LG G1 have a plastic film on the back that you need to peel off, like the CX/C1? Only asking as it’ll be getting wall mounted straight out of the box and I’m not going to get chance to check this.
Such as any difficulties with moving the TV towards and away from the wall with ease - just in case cables need switching or the TV needs to be taken down.
The cable is hard wired in, so you can’t replace it.Hello can anyone tell me the length and type of power cable supplied with the G1? I'm in the EU (Denmark) and want to buy a longer cable if needed because of the TV placement before it arrives.
It’s about 150cm though I think.
Totally agree. I ended up cutting my cable to thread through a wall. This is where Samsung is streets ahead with the single cable control box setup.Absolutely ridiculous decision by LG not to make the power cable detachable.
They must expect you to chase the plug through the wall as well!Totally agree. I ended up cutting my cable to thread through a wall. This is where Samsung is streets ahead with the single cable control box setup.
Your best bet is to subscribe to the OLED Bargains Thread here at AVF and also set an alert up on HUKD. If you want the flexibility of price-matching upto a month after purchase then John Lewis do provide that luxury.Anyone aware of any discount codes available for this TV?
Cheers.
