LG Firmware and John Lewis
Discussion in 'LG TVs Forum' started by David Waltham, Apr 6, 2005.
  1. David Waltham
    David Waltham
    just got off the phone from John Lewis High Wycombe having called to order an LG42PX11. It seems the version in the showroom and in the warehouse runs the 3. Firmware. Is this a branch by branch affair and worth searching elsewhere. Its being offered now for 1499 down from 1599 last week. Anyone managed to get a 5.10/5.13 Firmaware from John Lewis recently?
  2. lawrenso
    lawrenso
    Oct 6, 2003
    1,185
    48
    Flintshire
    +35
    I got one about 2 1/2 weeks ago and it was 5.14 - This was from JL Liverpool
    Lawrenso
  3. VSC
    VSC
    Mar 3, 2005
    25
    3
    Their display model will have been on display for sometime and will therefore run on the 3. software. Their stock models really depend on manufacture date, but due to the size of the company I'd expect their sales to be high enough for the stock to be of fairly recent manufacture date. Hope this helps.
  4. the highlander
    the highlander
    Mar 29, 2005
    177
    Bonnie Banks O' Loch Lomond
    i received a 5.14 from JL Glasgow 2 days ago :thumbsup:
  5. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,427
    83
    Stockton on Tees
    +174
    5.14 from JL Newcastle about 2.5 weeks ago :thumbsup:
  6. PSD
    PSD
    Feb 23, 2005
    1,309
    Tickhill NR Doncaster
    +110
    I got 5.13 from JL Sheffield 6 weeks ago. I don`t think that any of the stock will be 3.x., we have been on 5.x since last November/December. However, the display models will most likely be the older 3.x panels.
    Paul
  7. bananas
    bananas
    Dec 29, 2000
    109
    West Byfleet, Surrey
    I got my 5.14 version from the Kingston branch delivered yesterday. Interestingly I can see through the vents on the back of the screen, and it was manufactured in Dec 2004, so I was a bit concerned it would be a lesser firmware, luckily this was not the case.
    I think you'll be very unluckly not to get a 5.13 or 5.14 firmware model from JL considering the amount of these they sell.
  8. David Waltham
    David Waltham
    thanks, guys. it appears there are a proportion of LGs supporting lower versions of the firmware sitting in the Lewis warehouses. perhaps not many but they are there lurkingn in the shadows - the one on show at the HIgh Wycombe branch was pulled up from the warehouse only one month ago. It's worth reminding people to press menu on the remote and new set simultaneously to check just in case someone get on the wrong side of the probability ratio and puts the poorer picture down to running in time. Mine arrives next Thursday - fantabulous (after I've checked!)
  9. tgl
    tgl
    Mar 2, 2005
    171
    +3
    Their price is higher than JL by £100, but Comet will price match with them, so you should be ok via that route too.
