Answered LG E7 Sound Issues
Discussion in 'LG TVs Forum' started by antmatz, Jan 9, 2018.
  1. antmatz
    antmatz
    Mar 3, 2010
    25
    3
    +6
    Hi all, tried searching for my issues but not found.
    1. Anyone else have the situation where audio simply disappears? This has been known a few times when watching sky Q. Audio just drops out. Dead. No remote touched. Fixed with a case of turning things off and on or sometimes by changing sources. This has happened a couple of times.
    2. I'm struggling with lip sync issues too. Never had this with either of previous 2 TV's, both which had the almost same AV setup.
    I have sky Q plugged into TV via HDMI. Optical out of TV into AVR.
    I have AV sync adjust on the TV, Sky Q and AVR but unsure which one is best to start with.
    Once i have it where i am happy with, then i swap channels or sources and it seems slightly off again. Really frustrating.
    Any ideas would be well received. Ta
  2. Best Answer:
    Post #2 by rborhara, Jan 10, 2018 (1 points)
  3. rborhara
    rborhara
    Dec 26, 2009
    278
    28
    +44
    Best Answer
    Yep its a bug - everyone affected is waiting for a firmware update. see one of the threads called firmware update via usb
  4. antmatz
    antmatz
    Mar 3, 2010
    25
    3
    +6
    Thanks for the heads up, i'll take a look.
