LG DVD/VCR V9122W handset hack for region free
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Dargie, Aug 18, 2005.
  1. Dargie
    Dargie
    Works for many LG DVD players as far as I can gather including the V9122W VCR/DVD Combo I picked up today here in New Zealand factory set to Region 4. :clap:
    LG Region Free hack
    To Change the Region Code -
    1. Power DVD/VCR on. Wait for "disc" to be displayed
    2. Press the Pause button on your remote control
    3. Using your remote control enter the code 3, 1, 4, 1, 5, 9
    Note: If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.
    4. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
    5. Press the Pause button on your remote control
    6. Power off your player and wait a few seconds
    To view the firmware version -
    1. Power on your player
    2. Press the Setup button on your remote control
    3. Select TV Aspect and place the cursor on the 16:9 Wide option
    4. Using your remote control enter the code 1, 3, 9, 7, 1, 3, 9
    5. Press the Enter button on your remote control
    You should now see the version information screen
    :smashin:
  2. satolite
    satolite
    I am hoping to buy LG Dvd/VCR and was lucky enough to see a notation referring to this site.This is all new to me and at times a bit mind bending but as I have an inquisative nature I get involved.Thanks again.
    Satolite.
