LG DVD-5083 & DVD-5183 multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 22, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,811
    2
    167
    Birmingham, UK
    +9,530
    * Power On the player with no disc
    * Press Pause, 1, 4, 7 and 2
    * Press the Up arrow 3 times, the characters 04 05 should then appear on the display
    * Press Program 6, Program 5, the characters should then change to 04 FE, if they don't then continue pressing until they do
    * Press Enter
    * Power the player Off then back On again
    SVCD Hack:
    * Press up arrow 6 times, the characters 07 00 should appear on the display
    * Press Program 6, Program 5, the characters should then change to 07 FE, if they don't then continue pressing until they do
    * Press Enter
