Lg Dr4912 recorder Remote Hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by esoxcrazy, Feb 17, 2005.
  1. esoxcrazy
    esoxcrazy
    May 26, 2004
    Thinking of getting this dvd recorder but i'm wondering is there a remote hack for multi region use.
  2. daveyjay
    daveyjay
    Nov 18, 2004
    59
    +10
    Open tray-press"0" seven times-message comes up on screen"Congratulations"
  3. esoxcrazy
    esoxcrazy
    May 26, 2004
    Ok thanks
    The machine is being delivered today and I shall give it a go
    Thanks again
  4. csean2005
    csean2005
    I have a new LG DR4912. The hack sounds pretty easy, but I'm having problems. When I open the tray using the remote control, then press 0 (zero) seven times, I don't get any feedback from the recorder.
    - I don't see the zeroes being input (either on recorder's screen or TV screen that the recorder is hooked up to via Scart, with recorder on AV1)
    - I don't get any "congratulastions" message
    Recorder remains region 2.
    Could someone kindly provide the "hack for dummies" in a step-by-step? Essentially, WHERE do you see if the commands are being carried out, messages on screen, etc.?
