lg dr4810 and sky plus
Discussion in 'Blu-ray & DVD Players & Recorders' started by conorandlucy, Jan 1, 2005.
  1. conorandlucy
    conorandlucy
    I have Sky Plus and a LG DR4810 DVR. Whne i try to record the programs to dvd -rw disks they play on the machine used to record them but not on other dvd players. One of our other dvd players says on the from that it plays -rw but it just says no disc. I have tried finalising the disdc but that makes no difference.
    Any help would be greatfully received. :lease: :thumbsup:
    Conorandlucy
  2. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    Are you recording in 'VR' mode or 'VIDEO' mode? I think that by default it records in VR mode which means it's not designed to play on another player, it's mainly for better editing and disc space managment.
    If you go into the menu you can change the setting to video mode.
  3. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    PS have you read my confusing cabling post from earlier today, it might be of interest to you.
    I have found that when set to video mode it's quicker to start up and spends less time reading the disc.
  4. conorandlucy
    conorandlucy
    Thanks.
    How do you change to video mode though?
  5. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    Page 25 of the manual:
    DISC FORMAT - press 'setup' use up/down to select disc option.
    while disc option is selected press > to move to second level
    use up/down to select disc format option
    press > to move to third level (start icon is highlighted)
    press enter (disc format menu appears)
    use < > to select desired disc format mode then press enter.
    ( anything recorded on disc will be erased when the disc is initialized )
