LG DR4810 and LG DR4912
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Dibbiedibbie, Sep 22, 2004.
  1. Dibbiedibbie
    Dibbiedibbie
    The multi-region hack listed for the LG DR4810 also works for the DR4912 model:
    Press open to open the tray
    Press 0000000 (zero, seven times) and select ok when you get the congratulations message
  2. the mechanic
    the mechanic
    Nov 30, 2003
    1,232
    Wrexham,North Wales
    +52
    This method also works on the LG RH7500 DVD-HDD recorder, but you may have to try playing a disc from another region first, wait for the warning message and the disc to eject, with the drawer still open ( and disc still in place) press ZERO on the remote SEVEN times ( 0 0 0 0 0 0 0 ), then you get the message congratulating you, press ENTER, press EJECT to load the previously un playable disc and it will now play.... :thumbsup: ....
    TTFN,
    Graham.
  3. diane8631
    diane8631
    Thnak you so much for this tip, as a matter of interest, it worked for my LG model LH-T550 dvd player. Thanks again..... Diane x:clap:x
