LG DP8821 Portable DVD Player
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by kliker, Dec 31, 2004.
  1. kliker
    kliker
    I received this portable DVD player as aXmas gift, but found out that it is a Region 3 player. Is there a hack for this one ?
    Thanks !
  2. kliker
    kliker
    I found this on another forum and it worked !!!
    The following worked on two different models of LG DVD Players set to Region 4.
    "NO DISK" on Display
    Press "PAUSE" on Remote then enter "3 1 4 1 5 9"
    "DISPLAY CODE" enter "0"
    Good Luck
