LG Double Layer 12x DVD DUAL R/RW/RAM IDE Burner
Discussion in 'Blu-ray & DVD Players & Recorders' started by RecordablDVDfan, Jul 7, 2004.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    How long have these double layer DVD writers been out ? Does this mean I can at last make perfect loss free copies of DVD's ?
    What is the difference between dual layer and double layer though ?
    £71.67 on ebuyer at the moment !
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    A few weeks - Sony, LG, Philips and others all have the drives out. No dual layer media is currently available though :(
    Yes with appropriate software - although given that dual layer media is £10-£12 per piece it might be cheaper to buy a second comercial DVD :)
  3. 38H21543
    38H21543
    Jan 6, 2004
    195
    +8
    What is needed for the DVD playing device to be able to play "dual layer"?
  4. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    All DVDs can play dual layered disks, some are better than others when handling the pause between layers.
  5. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    But there are double layer DVD's available. look on ebay uk.
  6. HMHB
    HMHB
    Nov 11, 2001
    26,632
    Nottinghamshire
    +5,335
    Beware when writing to dual layer discs as they will only write at 2.4x and so will take 45 minutes to complete one disc. I also believe that there are compatibility problems between certain high speed media and the writers.
  7. Lyricman
    Lyricman
    May 19, 2004
    243
    UK
    +21
    Saw some in PCWorld for around £80. They also had 12x DVD Burners for about £79.
