Thanks for the info
It's a bit of a mine field all this LCD TV specs
What I have been trying to-do is look at models that have the features I think I need.
When I started on this quest my thoughts were 30 - 32 flat TV with some scart inputs and that would do.
Now I am thinking spend a bit more and go for something a bit more future proof.
So my needs are
Digital Tuner (No point in getting analogue)
DVI (PC - Replace my Ageing tivo unit)
SCART (RGB - SKY +)
SCART (PANASONIC DVDR)
and for some future proof get HDMI ?
From the information I have been looking at DVI-D is HDMI and DVI - I is a PC only type connection
PC-In (D-Sub 15pin) PC In Digital - DVI-I
From LG Spec
Nothing like getting too confused
But I could have it completely wrong.
What would be nice is to be able to have a list of options that you check and then some software tells you to have a look at the following sets.
As personal preference as to design / make and other features that you did not know you needed will help make the choice.
Tim
