LG Da 5620--hooking up to SKY /PL2 etc
Discussion in 'Home Cinema Buying & Building' started by Armalig, Dec 14, 2004.
  1. Armalig
    Armalig
    Mar 18, 2004
    12
    Bit of a new comer to this
    Just got a great looking and hopefully great sounding 5620 system at a steal and was looking some help in getting it hooked up to my std NICAM 32" tv.
    I have no external aerial -I just use the digital signal from the SKY dish to cover all our viewing needs thru the AVscart.
    I am hoping that I can get the sound from our digital source played thru the cinema sattelite speakers etc using the PRo Logic 2 setup.
    Any advice on how to hook this up , (to get surround sound all the time even when not watching DVDs!)
    Thanks for any info :lease:
  2. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    I not familiar with your surround sound system, some systems can draw what it is on the screen through the scart connection.
    However, the standard way to do it is to connect via phono outputs on your tv to phono inputs on your amp. White and red plugs, hopefully both your tv and amp have these.
