MixMaster Rick
All,
I'm new to this forum so thanks in advance for your help.
In the next few weeks I will be purchasing a new TV and have narrowed it down to LG OLED. The question(s) I have are whether to purchase the CX or the GX. In a week I have an in-home consultation from Best Buy but I wanted to get your help as well. My focus is on a screen size no less than 75". My questions are below and again, thank you for your time.
Rick
- Are there any other manufacturers like Samsung QLED that offer the same quality as what I've heard about the LG OLED?
- From what I've seen, the main difference between the LG CX and GX series is the processor and the GX's ability to truly flush mount to my wall. Is this accurate?
- If I go with the GX flush mount, how do I wire up the TV to allow for future expansion? I don't want to hire Geek Squad to come out if I add a new HDMI component. Do I have to pre-wire in advance all available HDMI, USB, etc or is it easy to add devices after the fact?
- As I look at the rear-view pictures it looks like the wiring is flush mount but how do the cables snake into my wall? I see what looks like a second compartment on the bottom of the TV. Is that accurate?
- Sound...What do most of you do to provide surround sound; do you use Bluetooth or wired? As an example, I have a complete SONOS system including Playbar, Sub and two Play 1's in another room. Is this a good start or do you recommend something else?
- An associate at Best Buy mentioned that there is an external box that connects to the TV itself and it provides connections. Is this true?
- Lastly, to all OLED users, are you happy with it?
Rick
