LG CX (OLED65CX) 4K OLED TV Review & Comments
yba_us
jmacc
When they start offering 3D, I will start to take a serious interest.
They did start, 5 years ago... then stopped :rotfl: :smashin:
sheppty
Can anyone confirm the width and depth of the stand the panel sits on? I can’t find the exact dimensions online. I want to ensure it will fit on my TV stand. I know the panel will overhang either side but want to make sure the stand won’t hang off either side as well. Thanks indeed.
iangreasby
Mine is the 77 CX so I can't give you the exact dimensions. However, I measured that it would overhang by about 5mm each side (which I was happy with). When it arrived it doesn't overhang because the maximum width is actually raised slightly. The actual width that makes contact with the cabinet will be a bit less than advertised. In other words, if it's a close call you will be fine. Hope that makes sense! :)
sheppty
Thanks for the info.
FevreDream
I'm getting a CX at some point but happy to wait for the prices to start falling, so sometime between late this year (Black Friday maybe?) and Spring next year.
Tristan45
Get my 65CX from LG soon replaced by my dead 65B7,so hopefully see a picture improvement
phairplay
Hi guys,
I'm thinking on purchasing a new TV, I started by looking at the B9 and now moved to the CX (pushing my budget for a new model).
I'm wanting to ditch my shield and use the LG internal apps to play: Plex, Netflix, Amazon prime and Disney + and have the sound sent to a soundbar (currently like the look of the Sony HT ZF9).
Does the above internal apps pass D-Atmos ect to a soundbar (ZF9 does support eARC)
Scott_Mac
Hi guys,
I'm waiting on this too... the C9 certainly doesn't - or rather to clarify, it doesn't send it lossless, it can send Atmos but not TrueHD with Atmos. So for Netflix etc it is absolutely fine as it will send as good as they provide, Plex is more of an issue as a result.
I ended up having to buy a Shield as a result :(
phairplay
another question if someone could help
Whats the difference between CX5LB and the CX6LA
I can't seem to see a clear answer anywhere
phairplay
Great that makes no difference to me as its going on the wall.
Also it seems 6la is exclusive to currys
kiran_mk2
It was reported on the US-based AVS Forum that the internal apps cannot access the eARC functionality and that as this is a limit of the Alpha9 processor (gen 2 in C9 and gen 3 in CX) it can't be fixed via a software update. As mentioned, the easy way around this is to buy and Apple TV (or similar) and use an App like Plex or Infuse.
kenshingintoki
Hi guys,
why do you wan tto ditch using the shield?
I'm looking to personally buy a shield or apple TV. I just find a device that little bit more stable and obviously excellent for playing properly with the receiver and giving me most of the available display options.
jmacc
Hi guys,
If your end goal is ditching the shield and using internal apps then maybe the 2020 lg oleds are not for you :(
No BBC iPlayer, Ch4, ITV apps etc this year.. And nothing to suggest the 2020 range will get them.
jmacc
Haven't been following any of the earc stuff but I'm considering a soundbar.
So with internal apps, If netflix say's dolby digital.. it will output atmos but a crapper version of it?
kenshingintoki
I just watched the Witcher with Atmos via internal app and my Denon showed ATMOS and noise was coming from the ceiling so it works. :)
Scott_Mac
For me, I had to buy it just to get Lossless Audio via Plex. I find it much more clunky and unstable than the built in apps. I use it purely for Plex, everything else I run direct... so it's a rather expensive solution to a problem that I was hoping could be solved by the TV itself!
gunner84
I use internal apps, I have really streamlined everything, took out my apple tv 4k box and use all the apps on the TV now, not fussed about BBC iplayer, used that app very rarely.
I still have my oppo203 to get best audio available, although having sonos arc DTS is an issue. but for lossless atmos its fine.
Is there much difference between Atmos DD+ and Atmos True HD, not really compared yet myself.
phairplay
I did think about that but its not a deal breaker for me I run plex and *Cough* acquire everything I watch from the likes of BBC C4 Sky ect
kiran_mk2
The CX is more complicated than it should be:
Interal apps --> limited to ARC (i.e. Dolby Digital Plus Atmos is the best you will get)
External device--> all Dolby formats passed through eARC (inlcuding Dolby TruHD Atmos), but NO DTS tracks (DTS, DTS-HD, DTS-MA, DTS:X)
jmacc
Thanks for that :thumbsup:
Is there a big noticeable difference from Dolby Digital Plus Atmos to proper Atmos or not really to the average joe?
How about the c9, does that pass full atmos from internal apps?
When Sonos add LPCM willl that make a difference to internal apps etc?
God I sound like such a n00b with all this audio stuff :blush::blush::rotfl::rotfl::rolleyes:
gunner84
Both C9 and C10 can't pass full fat atmos from internal apps, due to the alpha 9 processor.
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
Latest News
BAFTA 2021 awards sees Nomadland as big winner
  • By Andy Bassett
  • Published
What's new on Netflix UK for May 2021
  • By Andy Bassett
  • Published
Samsung rumoured to be buying OLED TV panels from LG Display
  • By Andy Bassett
  • Published
Netflix signs with Sony for first streaming rights in U.S.
  • By Andy Bassett
  • Published
Audio Pro launches C10 MkII speaker
  • By Andy Bassett
  • Published
