chenks
How can I check on the hours used on my 77CX
if you are outside the US then you need to go into the service menu.
within the US i believe it's in the settings support menu (see video showing the settings screen)
You have to access the service menu.How can I check on the hours used on my 77CX
Cannot be done with the magic remote.
I don't believe Cheltenham has moved to the US!unless you are in the US, in which case you can.
As you are in the UK and as said earlier you need a Service Remote.How can I check on the hours used on my 77CX
You didn't know because you didn't look.Not knowing where the OP is from I gave the answer for both regions (US and non-US), which will help if someone else looks for the answer
The info is there for everyone to see.
I prefer the personal touch, replying to the original poster, i.e., @Tristan45.
But is my comment an issue for you?
Really?
Never commented your answer, sorry.No issue from me. The answer i gave the OP was full and correct
Click on the individuals name. The ignore button is in the pop up.Anyone know how to block or ignore? Does the forum have an ignore option so you don't see the person's posts?
My tv was mounted on the wall,they came and took it off and removed the brackets..I think i have still got the stand because they didn't take it or the remote.i had no box eitherpreparing the TV for collection and as i've alwasy had it vesa mounted this is my first attempt at trying to fit the table stand.
how does this actually fit? following the instructions results in the bottom 2 screws of the part that fits to the TV not being long enough, the plastic part of the stand isn't sitting flush to the TV, only the top 2 screws connect and screw in.
it's as if the metal part is stopping the mount fitting properly - the metal part is secured correctly as it's dictated by the 3 screws it uses.
if i remove the metal part completely the plastic part of the stand fits correctly.
am i missing something obvious?
I was sitting watching mine when they arrived but I thought they were going to check the tv out firstbefore deciding if it needed taken for repairHopefully gets secured in the van properly, well you done everything you could so rest is up to them.
At least you got the loan TV, better then a blank wall or conversion with the dog
Spoke to denon as had same similar issue ,they told me to assign cd input to hdmi 2 as its nearer the monitor 1 input and the information for handshake issue, has less distance to travel along motherboard , have to say all is working normal 2days later , keeping fingers crossedHopefully it's a HDMI issues fix, not that mines playing again.
Series X, sky q and new AVR Denon x3700 are playing well together since i cut the power to them for 10 mins
Your picture looks much better than mine, yours looks excellent31 year old Robocop 2 off the Nvidia Shield Pro+Plex, Murphy's Veins pulsate with detail of the LG CX
What picture setting do you use?31 year old Robocop 2 off the Nvidia Shield Pro+Plex, Murphy's Veins pulsate with detail of the LG CX
I watched it sky q the other month and thought how great it looked for age on the CX..Its perhaps the Nvidia shield Pro it has an excellent upscaler tech built in
Filmmaker mode (User)
Oled 35
Contrast 96
Brightness 58
Sharpness 10
Colour 50
Tint 0
Advanced controls:
Dynamic contrast off
Super res off
colour gamut auto
gamma 2.4
peak brightness off
Picture options
noise reduction off
mpeg noise reduction off
smooth gradation off
black level auto
real cinema on by default and greyed out
motion eye care off
truemotion off
This is with brightness & contrast fine tweaked with the test patterns so I get spot on brightness and contrast levels, pitch black room also helps excel the OLED naturally.
Source : 1080p, 4.4gig mkv file
Where did you see this mentioned? I couldn’t find reference to it in the CX page or via Google.Rumours of a new SW on AVS - 03.21.18 no details on what it's supposed to correct as of yet.
As @Parry said, brightness 58 doesn’t seem right. Surely your blacks are more light grey at that level?Its perhaps the Nvidia shield Pro it has an excellent upscaler tech built in
Oled 35
Contrast 96
Brightness 58
Sharpness 10
Colour 50
Tint 0
Advanced controls:
Super res off
colour gamut auto
gamma 2.4
peak brightness off
Picture options
noise reduction off
black level auto
motion eye care off
truemotion off
If you take pictures on your phone, the quality will always look really good.Your picture looks much better than mine, yours looks excellent
