Winchesterclub
Thanks for this Andrew, is this the update for gaming issues ?03.21.16. Came through overnight today.
03.21.16 is the latest.What's the latest FW Number?
I've not had any notifications of Updates since getting the TV
Yep.Thanks for this Andrew, is this the update for gaming issues ?
In which case I think its identical to 03.21.09 which is available on the LG website for a USB update. That one fixes all the general TV watching issues, but messed up gaming at the same time.Thanks i will look out for it, do not do any gaming though
In my case a Yamaha RX-V381 with no sources powered up did it. I have no idea how common a scenario it could be, but there were several times when the standby light saved me from leaving the TV on overnight.
Thankfully the Marantz I have now triggers the art gallery screen savers.
My issue is my soundbar sends a static image to the TV saying there is no input... Well duh! And as it's static it's a screen burn risk. The art gallery is only on screen for about 1 second before the soundbar overrides it
For situations like these you can use the "screen off" function; the TV will still play audio but the screen goes black, I use it regularly for Spotify etc. You can add it as a shortcut by going to edit mode at the botton of the quick menu, clicking + and then selecting it
Hi VPFor situations like these you can use the "screen off" function; the TV will still play audio but the screen goes black, I use it regularly for Spotify etc. You can add it as a shortcut by going to edit mode at the botton of the quick menu, clicking + and then selecting it
Hi VP
If you add this function , does it recognise when Spotify is playing and auto turn the screen off ? Or do you have to do this manually
I presume you can say screen off via the mic function on the remote
Thanks for reply FM
So if you put say Spotify on does the screen automatically turn off ? If you have done the shortcut
Still have to manually click the screen off short cut on the remote, I hit control icon then screen off short cut and then it goes off this works on any app or any source, spotify, netflix, deezer, tidal, pc hdmi source or even Virgin media cable box hdmi source etc
Or hold mic button down on remote for few secs and say screen off
You can of course hold mic button down and say spotify or name of app and it opens, but far quicker to add it to the quick access button ie button 3 (spotify) for example so you just long press 3 to get spotify up.
Its not difficult to do just hit the 0 button (quick access) and press box 1 and it ask you what short cut you want hdmi 1 or xbox or spotify or netflix etc, plenty spare boxes also.
What would be awesome and lazy is if you are wanting to listen to spotify or tidal and quick access the screen off short cut rather then pressing control icon and then short cut, but that is really super lazy now that I read that back.
Had an engineer out today to inspect my second 77 CX. I was prepared to have to argue my case etc. I started by showing him a white slide for the grid/brush stroke effect. He immediately said "well that's not displaying proper white, that's all I need to see." I didn't even need to show him my banding issues. He said the white issues and the dead pixel were more than enough. He actually pointed out that I had tinting too. Never really looked for it but he was right.
Now the only decision is to go with a 3rd CX or go for an AG9, or even bail out of OLED all together....
It must be a ball ache swapping 77 inch TV's out, but I'd go third time lucky.Had an engineer out today to inspect my second 77 CX. I was prepared to have to argue my case etc. I started by showing him a white slide for the grid/brush stroke effect. He immediately said "well that's not displaying proper white, that's all I need to see." I didn't even need to show him my banding issues. He said the white issues and the dead pixel were more than enough. He actually pointed out that I had tinting too. Never really looked for it but he was right.
How do you add the Screen Off to the shortcut menu?
I have held down 0 but no option of screen off to add as a shortcut.
Thanks FM
Yes i have added Spotify to quick access
Thanks FM
Yes i have Spotify on the Quick Access menu, think i will say screen off sounds the laziest optionto me
Can you add Radio stations to the QA Menu ?
hit control button on remote
move cursor to left or click on edit mode
click +
click screen off short cut or which ever one you want it has lots on the list
you can also re-click edit and select any short cut on the left including screen off to move up or down
