Which size?
Which size?
Looks like this is an issue with the games as many people with different tv's are complaining about washed out blacks. Guess I just will have to endure it. Call Of Duty is so full of bugs it crashes my Series X every 5 mins.The only other thing I can think of is ensuring you have HDR calibrated on the console’s settings with HGIG on within the Dynamic Tone Mapping setting on the TV. I don’t have those games so can’t compare. Gears 5 is quite dark in places but it doesn’t seem grey to me.
Tried several cables which never made a difference, I have the V2 box so that might be the difference.I’ve never had a problem with my Sky Q box resetting to 1080? Never, since I’ve had the box. Either my V1 box or V3 box. I think maybe your HDMI cables might be the cause?
Yes, Deep Colour should be on for Sky Q!Just wondering if you need to enable the 'HDMI Ultra HD Deep Colour' option for UHD content if connecting a Sky Q box or in my case a VM V6 box ?
Anyone know if the Sky Q, VM V6 box support 'Ultra HD Deep Colour' ?
Whats your thoughts.
This is what the LG help screen says.
HDMI ULTRA HD Deep Colour
Picture Additional Settings HDMI ULTRA HD Deep Colour![]()
If you connect a device that supports HDMI ULTRA HD Deep Colour, you can enjoy a clearer image. After connecting the playback device, set HDMI ULTRA HD Deep Colour to On.
However, if the device doesn’t support it, it may not work properly.
In that case, change the TV’s HDMI ULTRA HD Deep Colour setting to Off.
Not really a massive difference tbh. Maybe the V3 is a touch sharper, but probably a placebo.As an aside, apart from the obvious HDR compatibility is there any difference in picture quality between the two? I've long thought my v1 box is a bit soft on both HD and UHD.
It happens to me now and again. It is well documented on the Sky forums and users have been reporting this for at least two years but the problem still persists.Anybody else having skyQ uhd problems my Cx has reverted back to 1080i, and I get error uho11 it doesn’t support uhd was working fine yesterday
I got the 8cm as I just needed to raise it up to avoid bottom right corner being blocked by a chair. However that is plenty high enough to put my Zidoo, Apple TV and Nvidia Shield under.Which size?
put it to what you like rather than what people tell you it should beHi, I have 2 question about gaming with PS5 :
1) Default Sharpness of this tv is 10.
For gaming console (PS5) should i leave it to 10 or i should put it to 0? I have read that some people put sharpness to 0.
2) Which is, in your opinion, the best colour temperature for gaming? I have read that the most accurate is warm2. But i think that is a little bit 'yellow'. I have put 'warm1'.
What do you think about? warm1 is ok or should i put warm2?
Yes, yes and yes.Has anyone paired a Sony HT-G700 soundbar with the CX?
Did it work ok with eARC? Was it a worthwhile improvement over the in built speakers?
Re: Any 2.1 certified hdmi cables out yet?
Yes. Also on AliExpress and ONLY if you buy from vendor Ugreen you will get 100% certified high quality stuff : 2.1 HDMI cable [email protected] 48Gbps HDR10+
Example 2m HDMI 2.1 cable, price BPS 7.64 (PVC Delicate Model) or BPS 12.10 (Luxury Zinc Alloy) free shipping:
I bought the outside PVC version in select box 'Choose color' and it's OK![]()
US $8.28 42% OFF|Ugreen HDMI 2.1 Cable for Xiaomi Mi Box HDMI Cable 8K/60Hz 4K/120Hz 48Gbps Digital Cables for PS5 PS4 HDMI Splitter 8K HDMI 2.1| | - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Everybody sees colour differently. If you prefer warm1, use warm 1. I also prefer a cooler picture.What do you think about? warm1 is ok or should i put warm2?
Wow I must be very lucky as mine hasn’t done it once!It happens to me now and again. It is well documented on the Sky forums and users have been reporting this for at least two years but the problem still persists.
It’s a Sky issue and nothing to do with the CX or your cables.
You have to go into settings on your Sky Q and re-select 2160 as your resolution.
TV USB ports can definitely power bias lightingQuestion whats the amp output on the usb ports?
wondering if the usb port can power some bias lighting? or a psclassic ? or both
I think "suck it and see" is the answer. I know it wouldn't power my Roku Streaming Stick – I had to use the mains plug.wondering if the usb port can power some bias lighting? or a psclassic ? or both
Is that deep enough? This tv has a fat bottom
