LG CX how far from the wall?
peterbund
Hi.
The guy from this Youtube video below says that LG CX needs to be quite a lot away from the wall if you mount it on the wall. Can someone tell me how far from the wall can be the picture at the closest? I have a fairly small room so I don't want that the picture of this TV would be 20 centimeters or more away from the wall.
weeman2
Don't worry mate,it's nowhere near 20cm that's roughly 8 inches.
Unless you have a big chunky wall bracket.
The 55 and 65" CX are only 46.9mm thick,so add that onto your wall bracket thickness and it should be roughly 100mm or less if you get a thin wall bracket.
If you want a tv close to the wall you should consider the LG GX,as that thing hanging on the wall is only about 25mm thick.
george
Samsung Micro LED, Mini LED, NEO QLED TVs and More: AVForums Podcast Interview
