LG CX apps and Sonos Playbar
cannco129
Hi all
Just purchased a CX65 and am really enjoying the picture quality, a big step up from my previous tv.
I have a Sonos Playbar 5.1 set up and have been trying to get this to work properly with the LG CX.
As the Playbar doesn't have HDMI it's connected to the tv by optical.
My problem is when I use the tv apps (Disney+/Netflix/Apple TV) I don't get 5.1 through the optical connection, only stereo PCM 2.0.
Are the CX tv's limited to only passing 2.0 through optical from native apps as this is something I wasn't aware of previously?
chenks
Suspended
have you set the TV to the correct audio settings to suit what the soundbar is expecting to receive over optical?
cannco129
I'm still getting to grips with the TV, have the sound set to "Optical". Are there other options to adjust the sound I need to change?
chenks
Suspended
is the soundbar set to PCM or bitstream?
cannco129
There are no settings on the Playbar you can adjust.
My set up uses an optical switch (4 in 1 out) with the output going directly to the Playbar.
This allows me to switch the audio to each device when needed.
Virgin media HDMI to TV and optical out to switch
Samsung 4k bluray player HDMI to TV optical out to switch
PS4pro HDMI to TV and optical out to switch
LG CX Optical out to switch
I can get 5.1 from the 3 external devices, but when I use the TVs own apps the sound shows up as stereo 2.0 in the Sonos app, so I'm thinking the TV can't or won't pass 5.1 through the optical cable - is that correct?
cannco129
Figured it out with the help of LG support, all tv apps showing 5.1 now which is excellent news!
The default setting for digital sound out on the tv is pcm for some reason....
"To adjust the settings go to settings, all settings, sound, additional settings, digital sound out, then change this to auto or pass through"
chenks
Suspended
that's what i was alluding to in the first reply, but couldn't remember the exact menu structure.
cannco129
Hi chenks.
Thanks for trying to help. Coming from an older tv there's a lot to figure out with this one!
chenks
Suspended
note that with optical you are limiting yourself.
you won't get the better sounds formates available from the streaming services as optical doesn't support them, only HDMI does.
