Sptz
Established Member
Anyone with an LG C9 and XSX. I've been using it with the following settings:
Had loads of issues regarding mangenta flickering and glitches all around, most of the time they were very occasional and not a massive nuisance UNTIL I decided to play Man of Medan, this game should be a benchmark for these issues, even in the menu everything was flickering, the black bars were raised (raised blacks) the entire screen flickering like mad.
Changed Refresh Rate to 60hz and it fixed the flickering but the blacks were raised still, looked more grey than black. So I decided to change input to Console Mode and Refresh Rate back to 120hz and wow.... Blacks are now fully black plus no flickering, everything looks insanely good.
I'm so annoyed at all these issues, I don't care if it's not 4:4:4 chroma, it looks better and there's no glitches all over the place and blacks are full black now... If it wasn't for this game I'd have kept the same settings and thank god I found it which prompted me to change it. I wish I could use PC Input but it's not working for me.
I don't understand why this is happening, what is the exact cause but this is my experience and Man of Meda being such a dark game and apparently picky, it shows off any issues even just hanging around in the Menu, so I'd suggest to try it out and post your results here? It's free on Game Pass.
- HDMI Port 1 - using following cable Amazon product ASIN B08BTXZGK7
- As seen in Vincent's video on how he fixed flickering with an RTX 3080 I believe.
- PC Input
- 4K 120hz
- Bit Depth: 10bit or 8bit (can't see any difference)
- Color Space: Auto (Standard)
- Low Black Level (SDR and HDR)
- Ycc 4:2:2 OFF
- VRR ON
- Tone Mapping: HGIG
