Waynej
The LG C8 is my first OLED so I may not be up on the correct terminology.
I've avoided testing for such issues and just tried to enjoy the TV. I am sure this was not present before as I have used the Xbox with the TV for several days now. On the Xbox settings screen there appears to be a light vertical stripe all the way down the screen. As I say I believe it's just appeared out the blue.
From various other posts around here I believe you all refer to this as vertical banding.
Is this common and every OLED has this? Is it deemed a fault?
After searching more I saw the Marco Polo scene that is commonly recommended to test as normal content. I can see it in this and a couple more bands too.
Will this go away?
I got the TV from Richer Sounds and it's less than a week old.
Will this go away?
