Answered LG C8 slow wifi
Discussion in 'OLED TVs Forum' started by LED175, Dec 9, 2018 at 12:00 AM.
Tags:
  1. LED175
    LED175
    Feb 5, 2014
    92
    +13
    I’ve just set up my new c8. I’m a little bit underwhelmed with the WiFi and webos. Stuff like youtube is painstakingly slow and the content plays in very low resolution despite them being HD and 4K videos, whether this is on YouTube or Netflix. A lot of the time when I select the relevant apps it says there is no WiFi connection and it buffers a lot even though I have very fast internet. The router is in same room about 12 feet away. I’ve never had this type of issue on my previous Samsung tv which was flawless on the wifi and for playing online content. Please help.
  2. Best Answer:
    Post #2 by wezzywebb, Dec 9, 2018 at 12:01 AM (1 points)
  3. wezzywebb
    wezzywebb
    Feb 12, 2004
    7,761
    2
    fishburn
    +7,081
    Best Answer
    5GHZ wifi ? if so set your channel to 36 in your router
  4. fat jez
    fat jez
    Jan 6, 2007
    3,591
    2
    Glasgow
    +846
    if the router is in the same room, is ethernet an option?
  5. chaparral
    chaparral
    Apr 8, 2006
    1,801
    Planet Earth
    +194
    I don't own an LG TV
    But a lot of people have said if you turn off listening mode it fixes the slow wifi speeds
  6. LED175
    LED175
    Feb 5, 2014
    92
    +13
    Ethernet is not an option.
    5ghz? Don’t know what that means. How do I set to channel 36? I am on sky q fibre and I am a bit of a novice on this type of thing. The channels only go up to 13 and I’m on 11 at the moment.
  7. LED175
    LED175
    Feb 5, 2014
    92
    +13
    I’ll try that, although I don’t know what listening mode is....guess it’s an option somewhere.
  8. chaparral
    chaparral
    Apr 8, 2006
    1,801
    Planet Earth
    +194
  9. LED175
    LED175
    Feb 5, 2014
    92
    +13
    Can anyone tell me how to turn off listen mode? I’m going into screen share app but there are no options within it!
  10. chaparral
    chaparral
    Apr 8, 2006
    1,801
    Planet Earth
    +194
    Post from the c8 thread
    LG OLED C8 owners and discussion
  11. LED175
    LED175
    Feb 5, 2014
    92
    +13
    Thanks but that listen mode is not available for me as I have no devices connected. Furthermore, I cannot connect any device as I only have apple devices which I don’t think connect.
  12. LED175
    LED175
    Feb 5, 2014
    92
    +13
    This is all that shows for me and I can’t go any further forward.
  13. chaparral
    chaparral
    Apr 8, 2006
    1,801
    Planet Earth
    +194
    You be best to put a post asking about this in the LG C8 owners thread..
  14. fat jez
    fat jez
    Jan 6, 2007
    3,591
    2
    Glasgow
    +846
    Channels 1-13 are on the 2.4GHz frequency. 36 and above are on the 5GHz frequency.
    Change your Sky WiFi channel
  15. LED175
    LED175
    Feb 5, 2014
    92
    +13
    The sky q hub only goes to channel 13. There is no option for channel 36. I have the q hub, that link I believe is for the old sky hub.
  16. fat jez
    fat jez
    Jan 6, 2007
    3,591
    2
    Glasgow
    +846
    Yes, it looks as though Sky have reserved 5GHz for the Sky Q multiroom backhaul. And you're right about it going up to channel 13, I was thinking of only using channels 1,6 and 11 when I wrote my post. I'll amend it.
    The LG TV should be fine on the 2.4GHz range, it's only the 5GHz range it's fussy about which wifi channel it uses.
  17. LED175
    LED175
    Feb 5, 2014
    92
    +13
    Can I select the 2.4ghz range without it affecting my multi room?
  18. fat jez
    fat jez
    Jan 6, 2007
    3,591
    2
    Glasgow
    +846
    2.4GHz is all it seems Sky give you with their router, they keep 5GHz for their multiroom use, so 2.4 is what you are already using.
    I don't have Sky broadband so my Sky Q setup created its own private 5GHz network, connecting my mini box to my main Sky Q 2TB box.
  19. LED175
    LED175
    Feb 5, 2014
    92
    +13
    It now works today without having to change anything. Hopefully it remains ok.
  20. MannyToor
    MannyToor
    Aug 1, 2017
    3
    London
    I had the same issue with my C7 where the connection was slow and some apps would not connect. I made the following changes which seems to have resolved the issue.
    Switch to 2.4GHz wifi.
    Changed the DNS to Google. 8.8.8.8 or 8.8.4.4
    Disabled listening mode.
    Disabled quick start under general settings.
    Updated to the latest firmware and disabled IPV6 under the network settings.
