fulllupo
Established Member
Hi All,
Need help to fix an issue in the hope of not having to replace the tv please!
Basically it’s like someone’s leaning on the volume up and ‘right’ on the remote. When I turn on the tv the volume bar just raises all the way to 100. If I pick up the remote I can kind of battle against it by pressing volume down repeatedly but eventually I lose and it’s back to 100. It also appears to be pressing right too, as if I go onto the menu’s to try to reset/adjust settings they just cycle to the right so I can’t even control them. I did manage to reset it but alas it’s the same when it turned on again.
Just in case there was a rogue remote someone I collected them all and removed batteries but it didn’t stop it.
Any ideas? Google brings up a similar problem with the odd LG tv, but most have physical controls on the tv that once pressed seem to override the problem for a time. The C8 however doesn’t have any controls! Is it an issue with the main board and if so can they be replaced?
Thanks in advance if you can help.
Paul
Paul
