swordfish100
Hi There,
So I've had my LG C2 42" Setup for a month or so in my office, with a PS5 & Switch. A few days ago, I moved the Xbox from the living room on to the C2, which is where the problems began...
So the Xbox will work for a period of time with all the video settings maxed out 4K / 120hz etc etc. Then at some point in a transition between home and game, or going into settings (basically at any point where the screen going black to switch on/of HDR) the screen will switch to the 'no signal' screen in the attached pic and I'll have to switch the xbox off by the console button.
When I turn it back on, it starts up in 480p (see second image). When I go to settings, switch 'Display override' to HDMI and try to set to 4k, it gives me the following 'your tv can't do 4k' nonsense.
This then takes lots of hard resetting and fiddling to get back to my full 4k / 120 / HDR / dolby etc settings.
Any ideas?
LG said they haven't got a clue and can send someone to repair it. But I feel that because its intermittent and works for a period of time, it is some sort of settings issue.
The cables are HDMI 2.1 and the xbox has been on our downstairs tv for over a year with no problems at all. The PS5 and Switch (and soundbar) work with no problem at all.
The only think I can think of, I bought a new third party power cable for the xbox, but surely it couldn't be a power issue?
Another thing - I've yet to have it have this issue when set to 60hz, though it could be a coincidence. Though I didn't buy a 42 inch tv for 1400 quid to not use 120hz
Thanks so much
Any ideas?
Thanks so much
