LG C1 OLED Owners and Discussion Thread
Noggin_Staffs
Hi all, I am going to buy a C1 65".
I know they are in short supply so very few suppliers have them in stock.
I wonder if anyone knows the answers to a few questions?
1) Of the 3 different versions C14lb, C15la & C16la are they priced the same or is the C16la more expensive due to the WISA option?
2) I know some of you have laughed off the suggestion of ordering from LG direct but can the service really be that much different from a retail outlet and considering the offer of a 10% saving its very tempting?
3) Does this TV work well with a full sized behometh wall bracket, one that really swings out and tilts etc? It has the big side arms that fix to the TV and hook over the long rectangle faceplate for sliding etc. I have a big Pany plasma on it (very heavy).
Josh W
There newer video with value electronics guy and the guy who calibrates their tv's suggested Americans are getting the Evo panels in the C1 and LG simply make one panel now so its all part of the Evo line up. Europeans and even others may still get that "old" panel due to stock though, but more likely the American's get the new panel.
If LG are doing one type of panel now then id guess Sony and the others also get the Evo panel if not now or later.
The calibrator did suggest though the Lgs and Sonys are so good out the box its hard to tell if any difference since its so accurate, it sounds like LG maybe doing a bit of calibrating at the factory over say 2020 oleds now. Sony already do some calibration we know.
Yes, thanks. I'd started to watch the vid yesterday as well. They seemed confident all the US C1's are getting the newer panel, but not sure about the European ones. The guy suggested it may even be just the white back ones getting the older panels but they clearly weren't sure.
As a potential buyer based in the UK, I already know I'd be paying more than a US buyer, and find the idea that I might be getting an inferior product for the privilege quite intolerable.
I appreciate it's not a big deal for some, but personally certainly won't be pulling the trigger until I know exactly whats going on with this panel situation.
I'm surprised there's even the possibility LG is putting different spec hardware in machines with the same prefix product code.
Tommy Teapot
Is there a way to display the current resolution and details from the active source? I'm pretty sure I seen some quick remote button press to show those details.
JB14JP
Hello,
matter some help on these settings, if I may. It follows my issue I’m having with 5.1 only coming through 2 speakers on sound bar via Amazon Prime built in app... and I don’t know if any of these are playing a apart?
1) HDMI Input Audio Format - the only available port is ‘hdmi 1’ which is my virgin cable box -> options: Bitstream or PCM (I’m presuming my soundbar doesn't show up as this is not a sound input, so probably has no bearing on the above?)
2) Digital sound Output - should I be using PCM - Auto (which is what it is currently set on) - Pass Through?
Many Thanks
The Reflex77
To my eyes there is a noticeable improvement in the C1 ootb as opposed to the CX.
65-inch LG C1 Review coming soon to AVForums
