LG BX 4K OLED TV Review & Comments
Steve Burling
I’m confused why are you reviewing last years 2020 model again or am I missing something?
Phil Hinton
Editor
Staff member
We hadn't reviewed the BX and it is now available for under a grand and has almost everything most users will need, so it's a short review to highlight a model that has perhaps been forgotten about. We are yet to receive the 2021 models and at launch, they are going to be significantly more expensive.
OneEyedStuart
Thanks for the review Phil, apart from the black flicker / noise issue with below par content I'm incredibly pleased with the TV as a whole... well apart from the so called Magic Remote which is doing my head in at the moment. A recent firmware update means my Harmony system (which used to work flawlessly with the BX) is now a bit iffy.
ChuckMountain
Thanks, Phil, I am half tempted as would like to replace a 50" GT50 plasma with a 55" BX or CX and yes they are a good price now with around £150 difference in price between them. Interestingly the 48" versions seem to be a better price than the launch price last time. Still as much as a 55" but ok if you can't fit or want a biiig monitor :)
I don't really need to swap do I :suicide:
bonkersrob
I agree, I've noticed this flicker (or would you call it even a bit of flashing?) on Apple TV app last night, watching "Servant". I've come to the BX, after I tried the CX/ GX, which gave me real problems with picture quality, connected to Sky Q (micro stutter on certain content, via trumotion, which really stuffed up the motion interpolation support for the set, for my specific needs). The BX operates completely differently for me, in that specific respect, hence why I still have it in my lounge now. @Phil Hinton do you think that LG will look to try and fix or minimise this flicker/ flashing effect on near black content, in any future firmware upgrade/ fix, if possible?
bonkersrob
The BX, was being sold by Costco around a couple of weeks ago, for £911 inc VAT and the 5 year warranty!!
OneEyedStuart
New firmware is being rolled out which allows fine tuning of dark areas but appears to be specifically for VRR... don't know if we'll have access for standard content. I'll be looking later.
[EDIT] quoted wrong post, but you get the general idea.
Joe C
jizzlejimbo
Does it have 48gbps ports? I thought they were 40 like the CX?
Roedgroed78
Hi thanks for this review! Definitely a very good "entry level" OLED. And it appears that the B1 will not bring critical improvements. This was my wife's favourite model when we last could visit an AV store together.
The 65" model is now between 1,400 & 1,500€ in Belgium. Since the price of the CX has now oddly risen again over the 2,000€ bar, the only OLED alternative under that bar would be a Philips 65OLED805 at 1,999€ (1,699€ after cashback) (there may be better deals at online stores, but I prefer buying from an established physical store...).
Knowing the Philips doesn't have any HDMI 2.1 features but ALLM (we're not gamers right now, but I cannot exclude my preteen son wanting a PS5 or an XBox in a couple of years...), nor Dolby Vision IQ, but is arguably brighter and has a better sound system, do you guys think the price gap is justified for my fairly bright living room?
An alternative would be to wait for 2021 models like G1 or Pana JZ1500 deals during Black Friday or so, but I don't think they'll ever go under the 2,000€ bar...
jizzlejimbo
Phil Hinton
Editor
Staff member
The Rtings review seems to suggest otherwise that they're 40gbps.
I checked them with a Murideo Seven G which gives a full in-depth EDID readout showing they are 48Gbps. (FRL: 12Gbps @ 4 Lanes). I can't speak for Rtings and how they got their results.
ChuckMountain
Seems strange they borked the CX model. What did that show on the test?
Phil Hinton
Editor
Staff member
40Gbps. This is going to be standard across all OLED TVs from LG going forward, the BX was an exception to that and I presume because it was using a different board with only two HDMI 2.1 ports.
zubeir
@Phil Hinton
What are your thoughts about most OLED panels not being bright enough in nits to be able to display HDR correctly. This was based on the Vincent Teoh video, which made sense to me as content that is mastered higher than the peak brightness of most panels out there.
MEGATAMA
Hmm peak brightness is lower then what i had on B6 and B7 if i remember well.
No go in 2020/21
Roedgroed78
No go in 2020/21
If peak brightness were THE benchmark, only Samsung Q90/95s would be purchased, and nobody would be happy with their C9/CX, A8 or HZ1000, which - as all reviews around the world conclude - seem to deliver better overall picture quality than QLEDs. I can't judge by myself, though, since I'm still looking for the "best" TV to replace our 10 yo LG LCD... With a budget, of course.
jizzlejimbo
I get your point but you'd expect a peak brightness increase Vs a 3 year old model in the same class of product. BX Vs B7.
Brummy1875
Never had a problem with the brightness on my set, my mate has the CX and i cant tell the difference between the two, youd have to see them side by side i guess, im more than happy with my BX ticks all the boxes for me.
Roedgroed78
True, it's a pity, but there must be a reason related to burn-in issues... And on the other side I think there have been nice improvements, in terms of OS, HDMI 2.1, picture processing, etc.
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
Latest News
Samsung's 110-inch Micro LED TV on pre-order at Harrods
  • By Andy Bassett
  • Published
Bang & Olufsen introduces Beosound Emerge speaker
  • By Andy Bassett
  • Published
Sony launches native 4K VPL-VW290ES and VW890ES projectors
  • By Andy Bassett
  • Published
AVForums Podcast: 14th April 2021
  • By Phil Hinton
  • Published
Ruark introduces R5 Signature audio player
  • By Andy Bassett
  • Published
