scoobydoobydoo
Any issues in this release?
What’s the change in 5.30.03?
.65 is affected by crushed blacks. However, since you're on the 04 version you could potentially downgrade to 04.10.25 and have a normal picture.Hi guys just a quick question, I have had my 65 inch B8 for about 20 months now and apart from 1 stuck white pixel (can't see it unless close to TV) am happy with the picture, I have refrained from updating the software and the set is on 04.10.65 is it best to update to the latest firmware or should I keep it as is?
How come, which fw version did you have before? Do you use any IRE mod?Hi, i still don't have the black crush on firmware 5.10.40 and hope it stays that way
You dont have Black Crush because you've modified IRE, which dont work in Game Mode.I had 4.10.65 on him but i can remeber with which firmware i bought it.
I'm running this Settings:
ISF: / HDR Cinema / DolbyVision Cinema
OLED 17 / 100 / 50
Contrast 94 / 100 / 100
Brightness 50 / 50 / 50
Color 52 / 50 / 50
Tint G3 / 0 / ---
Warm 2 / Warm 2 / Warm 2
Gamma 2.4 / --- / ---
2-Point:
low R8 G0 B0 / low R1 G0 B-4 / ---
high R-1 G0 B0 / high R8 G0 B7 / ---
20-Point: (those are the only ones i changed)
30 R1 G0 B0
90 R-3 G0 B5
100 R0 G-10 B-3
SDR: AVSHD 709 mp4 Version, 1-Black Clipping.mp4
- ISF (Dark Room) with gamma 2.4 everything down to 17 (including) flashes.
HDR10: Mehanik HDR10 Patterns, 01. black-level-v1.mp4
- Cinema Mode, Dynamic tonemapping = off, down to 66 (including it) is visible.
Dolby Vision:
- DolbyVision Cinema Mode
In Netflix: Jessica Jones s03e10 bei 38:10, the seat padding, the clothing and even jessicas hair is distinguishable.
BlackPLUGE.U4K_DVp5.mp4 I can see both vertical bars on the right.
One chap has it who mentions it fixes a wifi issue from the last update. I don't know what part of the world he's from but nothing in the UK as of yet.Has 05.30.10 been released for B8's?
Can 05.30.10 firmware download from C8 support page installed to B8 or are the firmware files model specific?
Ok, that's good to know.B8 uses different firmware than the rest of the 2018 OLED line.
You can try different countries in Europe tough - exp. German and French sites list 5.30.02 atm, while UK 5.20.01.
I’m on .05.20.01Which firmware do you use now?
