Ringnut
If you don’t mind me asking how much is a calibration these days. The last time I had it done was 2013 on my Panny VT. which is still going strong.
Same answer, I don't know. Drop Gordon a message.
In what way? The LG is 300x200 I think, should be fineI think I’ve made a horrible error. The Invision mount I ordered doesn’t seem to fit
It says 200x200 up to 600x400 so I assumed it would fit but it doesn’t?
Dejudder is effective for up to 30fps content, deblur takes over for higher frame rates.Has anyone used true motion to any advantage?
I’m talking user setting specifically. Maybe for sports? I mean I could play with de-judder and de-blur for all eternity, but is there perhaps an ideal setting?
Thanks.
Can you connect Bluetooth headphones to this tv?
Mine does something similar. Occasionally When I turn the tv on it doesn’t power up my sound bar, so I get sound from the tv speakers inside. As soon as I turn on the sound bar it connects.Sometimes when I turn the TV on it forgets the ARC setting and resets it to sound out of the TV speakers. Any way to prevent this?
I had a similar panic momentWas just being silly. All done now.
USB stick?Quick slightly random question for you guys, I'm struggling to figure this out.
If I use the screenshot feature on the b7 is there any way to get that screenshot off the TV to my phone or any other device to use elsewhere?
That’s great thanks.Just measured my 55inch B7. Depth is 2.55cm, Width is 75cm.
Can anyone tell me the width and depth of the curved stand on the B7 please, it’s too long a thread to look through. Hopefully it’s under W72cm X D38cm
Thanks. I was hoping to get the Sonos Playbase to sit underneath the tv, but the width of it is 72cm. I really don’t want the stand sticking out either side. I haven’t bought the tv yet, so i might go for a C7 instead, if the width is smaller than 72cm.this sites very own review of the tv covered this
There is 70mm of clearance beneath the screen when using the stand, so bear that in mind if you're considering a soundbar. You'll need a surface that is at least 740 x 254mm on which to place the B7, although you can also wall mount it and there are 300x200 VESA brackets for that purpose. Overall the 55" B7 measures 1229 x 764 x 254mm (WxHxD) including the stand and weighs in at 18.6kg and, whilst it isn't quite as classy or well made as the more expensive E7, it's still a solid and attractive TV.
i had same question long time back
55” C7 is 57cm wide, and about 22cm deep.Thanks. I was hoping to get the Sonos Playbase to sit underneath the tv, but the width of it is 72cm. I really don’t want the stand sticking out either side. I haven’t bought the tv yet, so i might go for a C7 instead, if the width is smaller than 72cm.
