Question LG B7 Is a custom resolution safe?
Discussion in 'LG TVs Forum' started by InfiniteBri, Jan 12, 2019.
Tags:
  1. InfiniteBri
    InfiniteBri
    Jan 12, 2019
    England
    LG B7
    Iv created a custom resolution through NVIDIA settings ([email protected]), Everything seems ok.
    In game it says the correct resolution and with vertical sync on its locks at 120fps so I know it works.
    But is it safe for the tv long term? Will it overheat?
    Thanks.
  2. King Dazzar
    King Dazzar
    Jan 11, 2019
    Basingstoke
    I would think yes it will be OK. My understanding is that the panel is actually a 120hz 4k panel, which due to limitations of HDMI cant actually display 4k at 120hz via any of its connections.
