Quantcast
LG B6 OLED TV Owners and Discussion Thread - Part 6
fwokinfwok
I pressed and held the home and back button on the dog chewed one which seemed to unpair it. Is there another method I should try..?
SeeMoreDigital
If you select the TV's 'User Guide' and visit the 'How to Operate TV' option you will find the 'Magic Remote Control' instructions...
fwokinfwok
I’ve tried several times but I just get the message “only specific remote model can be paired”. Interestingly the stand by button stays Red for about 15 seconds every time I press the jog button.
This remote mustn’t be compatible
SeeMoreDigital
When viewing the 'Magic Remote Control' instructions in the TV's 'User Guide' did you try pressing the 'GUIDE' button (on the remote control) for 5 or more seconds?
If everything goes according to plan you should see 'on screen' information appear at the top right of the TV screen...
pcaddy
I was watching You Tube last night and it was fine no problems at all but that was using the TV App not the browser. I cannot see any reason not to use the App and use the browser myself. :)
Similar threads
