LG all in one hi-fi
Discussion in 'Home Cinema Buying & Building' started by googlybear, Apr 18, 2005.
  1. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    Hello all
    does anyone know what the latest 5.1 surround hi-fi system from LG is and if it is any good?
    i had an LGdv25 which was a great piece of kit (except for the loud fan inside). It has gone off for repair and cannot be repaired and so they will send me vouchers to replace it. (i dont know how much they are going to send)
    1. what would be the closest comparison to a 5.1 dvd,vcd, tape, radio hi-fi and how much would it cost (i dont want them to send me 50 quid and say make do) as the dv25 is no longer available
    any help would be appreciated
  2. Jonno65
    Jonno65
    Ive just bought the LH-CX245 from Richer Sounds
    Havent fully set it up yet but so far so good
    Buttons on remote a little small and the mechanics are a bit noisey otherwise seems a nice bit of kit and only £100!!!
    Ive also made it multi region as well
    http://www.area450.co.uk/lg5083hack.htm
    LG DVD-5063/5083/5095/5183/5253/6053
    multi region hack
