lg 850
Discussion in 'Blu-ray & DVD Players & Recorders' started by ataribaby, Nov 7, 2005.
  1. ataribaby
    ataribaby
    Nov 20, 2004
    +4
    i purchased a samsung d850 on saturday,have set it up using hdmi, run an optical lead to my amp, and it keeps coming up with a message on my screen (i have a pioneer plasma 436 xde) hdmi audio not supported! not quite sure what the problem is any ideas many thanks
    paul :confused:
  2. amorenod
    amorenod
    Sep 17, 2002
    483
    28
    +41
    A stupid "feature" of some Samsung DVD players. It means that your TV doesn't accept digital sound input via HDMI
    There're 2 solutions:
    - Setting the sound from Bitstream to PCM, but that disables Dolby Digital 5.1
    - Setting message OFF in the display menu every time the DVD is switched on (another "great feature", message is always ON everytime the DVD is switched on)
  3. ataribaby
    ataribaby
    Nov 20, 2004
    +4
    thanks for that so am i to assume that this pioneer 436 xde does not accept 5.1 audio from the said hdmi cable? bit dissapointed if this is the case!! do any tv's accept multi audio through the hdmi socket? a bit confused by it all!!!! :confused: :confused:
  4. amorenod
    amorenod
    Sep 17, 2002
    483
    28
    +41
    You should not, neither does my tv. Blame it on the player, the message is unnecessary, as you're using an extenal amp.
