LG 7000 Scratched table top stand
B
bertie1249
My dog keeps on jumping up to the telly and putting his paws on my LG stand. I've now noticed that he's scratched the shiny plastic table top stand that came with the tele.
Does anyone know what product is best to use to remove light scratches from black shiny plastic, it's really bothering me although they are not deep you can clearly see them because the plastic is so shiny and black, and i don't want to use any product that could cause more damage.
Any advice would be much appreciated.
J4CK DANIELS
if they aren't very deep you might be able to just polish them out with some 'thick' household polish OR try some toothpaste, i use toothpaste on my CD's and DVD's and it works a treat! :thumbsup:
RottenFox
if its scratched, theres not much to be done, to be honest.
you could try polishes,etc but in the end, if they are into the plastic, theres no getting rid of them.
