Yes, I'm writing up the B7 review right now and I actually compare the B7 and E7 in this review. The short version is that there really aren't any differences.Will you be reviewing the B7/C7 as well Steve? I appreciate they're much the same as the E7, but it would be nice to know for sure.
Come black friday, I suspect I'll finally go OLED with a 65" B7 or C7.
Anyone fancy buying a 10 year old KURO?
Do you agree with others that DV on OLED is a significant improvement over HDR10?You could wait and no doubt next year LG will add HFR support, HDMI 2.1 and perhaps get the brightness up a bit but I have to say that the B7 hits a sweet spot for me, especially now that Dolby Vision on Ultra HD Blu-ray is a reality. I've updated the firmware on the Oppo UDP-203 and I'm just waiting for my copies of Despicable Me 1 and 2 to arrive tomorrow and then I'll add a section on Dolby Vision to the review.
If you read my post you'll see I haven't got the discs yet but as soon as they arrive I'll update the review with my thoughts on DV.Do you agree with others that DV on OLED is a significant improvement over HDR10?
Oops, I clearly need remedial lessons in EnglishIf you read my post you'll see I haven't got the discs yet but as soon as they arrive I'll update my review with my thoughts on DV.
Thanks for a another very well written review.You could wait and no doubt next year LG will add HFR support, HDMI 2.1 and perhaps get the brightness up a bit but I have to say that the B7 hits a sweet spot for me, especially now that Dolby Vision on Ultra HD Blu-ray is a reality. I've updated the firmware on the Oppo UDP-203 and I'm just waiting for my copies of Despicable Me 1 and 2 to arrive tomorrow and then I'll add a section on Dolby Vision to the review.
Yes they do go back but I've still got the B7 and E7, so I can check those out and we'll obviously test DV on any supporting TVs going forward.How many of the TV-reviews will you be able to update with DV testing? (I suspect you have to send the TV:s back at some point?)
I've also just tested the B7 which didn't have any problems either and that was a retail sample.I take it that the TV you had was cherry picked from lg then? because the E7 I had came with both banding all the way to 20%ire and dark edges! See the pictures on page one of the E7 owners thread.
Will you compare it to the pictures I have posted in the owners thread and post a comparison?I've also just tested the B7 which didn't have any problems either and that was a retail sample.
Nice, really looking forward to thatYes they do go back but I've still got the B7 and E7, so I can check those out and we'll obviously test DV on any supporting TVs going forward.
Are you going to buy a B7 Steve for yourself?You could wait and no doubt next year LG will add HFR support, HDMI 2.1 and perhaps get the brightness up a bit but I have to say that the B7 hits a sweet spot for me, especially now that Dolby Vision on Ultra HD Blu-ray is a reality. I've updated the firmware on the Oppo UDP-203 and I'm just waiting for my copies of Despicable Me 1 and 2 to arrive tomorrow and then I'll add a section on Dolby Vision to the review.
Please also test dv from Netflix if possible..daredevil and some programs are streamed with dv apparentlyYes they do go back but I've still got the B7 and E7, so I can check those out and we'll obviously test DV on any supporting TVs going forward.
I'm seriously thinking about it.Are you going to buy a B7 Steve for yourself?
I know that Netflix supports Dolby Vision but the arrival of DV on 4K Ultra HD Blu-ray means that we can finally see what difference it actually makes in an easy to perform and repeatable fashion.Please also test dv from Netflix if possible..daredevil and some programs are streamed with dv apparently
CE Pro Europe
The A1 and E7 were very similar in terms of performance, there was a bit more banding on the A1 but it had better motion handling so it really comes down to personal preference."The A1 is a masterclass in minimalist design and will also support Dolby Vision but overall we preferred the look, features and performance of the E7." Not much difference in actual Picture Quality ?
Is there much of an upgrade between the 6th and 7th gen LG OLED? Could we be better off saving a £1,000 or more by going with the B6 or E6 compared to the B7/E7.
I do think the 2017 LG OLEDs are better than last year with a superior performance just above black, improved image accuracy and better handling of less than perfect content.So how is it compared with last years OLEDs picture wise? Some have mentioned it's better with sources that arent perfect and less noise/cleaner, did you think that too?
