woppy101
- Joined
- Sep 12, 2008
- Messages
- 6,641
- Reaction score
- 6,540
- Points
- 2,200
Hahahaha, right thenWant to know everything ,you have had all the 2018 sets you mad man (barring the new pannys),so fire away ,its down to YOU if I pull the trigger on a C8 ,,,,,,,,,,,no pressure
Samsung, very bright and quite good but the brightness fluctuations lack of black detail and DSE done my head in. Worst of the bunch
Sony, very good still better at motion than any of the others and is still slightly ahead of the LG processing wise and not as bright, but WTF goes on with the compensation cycles one day the panel is perfect and for the next 3 band hell then back to great again. I also didn’t have any problems with the OS but i was using AppleTV. Middle of the bunch
LG, processing is far better this year and only just behind the Sony, much brighter than last year mine was measured at over 800nits, motion is definitely improved but as I said still behind the Sony”in my opinion” panel uniformity is far far better then previous years which is the big one for me, and everyone knows how good LGs OS is .
Top of the tree for me
The E8 to me was just the same as the C8, panel uniformity was the same but I was only set up for a day as the screen failed.
If your making a choice between the Sony and the LG I would say the Sony if your choice is a 2017 or 2018 it’s a no brainer
