Delightful
Established Member
Does anyone have exact dimensions of this TV.
In particular, I would like to know the dimensions of the lower back-plate - width, height, distance from top, exactly where the VESA screw-holes are and the distance of these screw-hole from the bottom and top of TV.
I'm eager to get a full-motion TV mount but want to be 100% sure that it fits within the bounds of the back-plate and nothing is sticking out.
Currently eyeing up the Peerless, Vogels & Sanus. Couple of cheaper options on Amazon & Ebay, but need to make sure they fit perfectly.
What have you guys got in terms of TV mounts?
Any pics of your LG 65 C8 set-up with mount would be great
