Lg 52" vs Samsung 50" dlp
Discussion in 'TVs' started by Mauler57, May 8, 2005.
  1. Mauler57
    Mauler57
    Hi all i have looked everywhere for some info on the lg rt-52sz60db i cannot find any reviews. I have seen some info on the Samsung sp-50l3hx and it seems like a good tv. I have seen both in person and the samsung seemed to have a better crisper image but i like the size and look of the lg. From what i can see the lg uses the hd2 and the samsung uses the hd3. I know from experience the way the tv is setup makes a huge difference and i am sure both tv will look good but i dont want to regret my decision. I have a modded xbox and watch a lot of movies on it. Any recommedations or reviews would be much appreciated...I will be getting either one in less then a week
    Ps the lg is $500 cheaper as well
  2. Razor
    Razor
    Dec 15, 2004
    37,548
    2
    +12,508
    [edit]
    Mauler try the US version of these forums:
    http://www.avsforum.com/avs-vb/forumdisplay.php?daysprune=&forumid=63
    Even though I havent seen the LG, I would steer clear. Go for the samsung, a much better build quality :D
  3. malso
    malso
    Mar 24, 2005
    278
    16
    hi Mauler
    the SP50 is better. You do have to do your homework carefully before buying; for example, users have found that the Optoma RD65 (etc) display a serious judder when fed an NTSC video signal.
  4. Razor
    Razor
    Dec 15, 2004
    37,548
    2
    +12,508
    Malso
    I was the second person in the UK to recieve a RD65 and it was I that discovered the 60hz fault. Optoma didnt know anything about it.
