Quantcast
LG 50PZ570T Anygood? after a 3d smart tv
MxN
Hello therem im new so go easy on me,
Im new and after a 3D tv with the Smart internet (internet) fetures around the 47" - 50" dont want no smaller or bigger,
Ive got around £650 to spend and pushing up to £700
Ive came across the LG 50PZ570T with is a 50" smart 3d tv was wondering if anyone has one or any known bad points as im very near ordering one,
anotherone i came across was the panasonic 50st30, it has a good spec but ive seen one in the shop and the "bezel"? the outer edge design puts me off as its really thick.
Can anyone help me with the lg or recommend some tvs in my price range
Thank you
Jason Shouler
If you read many of the reviews then it suggests 2D performance is good but 3D leaves a lot to be desired.
If you really are looking for great 3D then I'd suggest you check out the LG SMART Passives since these tend to get far better user feedback (especially for 3D)
