LG 50PZ550T has turned itself off twice!
Discussion in 'LG TVs Forum' started by jocarl11, Jan 10, 2012.
  1. jocarl11
    jocarl11
    May 28, 2009
    11
    South Cumbria.
    +4
    Hi, Just bought my LG 50PZ550T 50" plasma 4 days ago and it's been perfect untill today when it switched itself off this morning and then did the same again this afternoon! As soon as it turned itself off I switched it back on by the remote and all was fine?? But to do this twice in 1 day when it's just 4 days old is a bit odd isn't it?
    Thanks.
  2. Lewis123
    Lewis123
    Feb 13, 2006
    512
    28
    Shoreham-by-sea
    +52
    Is it turning off after about 4 hours or so. Modern TV's have an energy saving 'feature' in that they turn off after a set amount of time if no buttons are pressed on the remote. I'm not sure how to turn it off but it will be mentioned in the manual somewhere.
  3. jocarl11
    jocarl11
    May 28, 2009
    11
    South Cumbria.
    +4
    Yes it probably was about 4 hours between the 2 so I will look into that.
    Thanks for your help!
